Homedics Shiatsu Massaging Cushion Logo
A
Anonymous Posted on Mar 26, 2014
Power button flashes
Wont work when turned on, but power button flashes blue
2helpful
2answers
My Nordmende television blue light below screen continually flashing & no tv screen.
Question edited for clarity, your television is 'Nordmende', not 'Norfmende'.
Time for a new one, but try the power reset first as mentioned here.
The standby light on my nordmende tv keeps flashing
JustAnswer https://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ...
1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
How to fix my nordmende tv as blue light is flashing and ...
Ask Me Fast https://www.askmefast.com > How_to_fix_my_nordm...
Its the power supply board, capacitor(s) have gone. Solder on new or replace board. source: 26" lowry tv red and blue standby light flashing and tv wont turn on?
2answers
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
10helpful
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
1helpful
Ps3 afterglow bluetooth flashes red and blue and wont let me talk, what do i do?
When the afterglow headset flashes from red to blue, it is in pairing state, youve held the power too long after power-on. Shut it off again and turn it back on and dont hold the power button untill it flashes red to blue. The directions provoded with it aare quite easy to follow. Took me 30 seconds to set mine up
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
1helpful
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
1helpful
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
1helpful
My LG kf750 secret wont start up, wont turn on. It
You could try to hard reset your device, in an attempt to sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all the programs you have installed, as well as your personal data. Anyway, to perform a hard reset, turn your phone off completely, by pressing and holding the power button, and, then, answering to the power off prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue now. When your device powers up, it should be completely cleared.
Hope it works for you, since this is completely theoretical. I have never done it myself.
Regards,
Carlos
5helpful
4answers
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Top Homedics Health & Beauty Experts
jws1013
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
