To obtain the passcode for pairing Bluetooth on your Pyle Hybrid Amplifier P2002ABTI, you will need to refer to the user manual or documentation that came with the amplifier. The passcode or PIN for Bluetooth pairing is typically specified in the manual, as it can vary depending on the manufacturer or model.
If you don't have access to the manual or cannot locate the passcode information, you can try some common default passcodes such as "0000" or "1234," as these are often used as default codes for Bluetooth devices. However, it's important to note that these default passcodes might not work for your specific amplifier model.
If none of the above options work, I recommend reaching out to Pyle's customer support directly. They should be able to provide you with the correct passcode or guide you through the pairing process for your Pyle Hybrid Amplifier P2002ABTI.
The Samsung WEP-150 passkey (or PIN, or pairing code) is '0000' (four zeros).
Please, let me know if you need further clarifications on how to pair your headset with other bluetooth enabled devices.
Cheers!
Carlos
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
