To obtain the passcode for pairing Bluetooth on your Pyle Hybrid Amplifier P2002ABTI, you will need to refer to the user manual or documentation that came with the amplifier. The passcode or PIN for Bluetooth pairing is typically specified in the manual, as it can vary depending on the manufacturer or model.
If you don't have access to the manual or cannot locate the passcode information, you can try some common default passcodes such as "0000" or "1234," as these are often used as default codes for Bluetooth devices. However, it's important to note that these default passcodes might not work for your specific amplifier model.
If none of the above options work, I recommend reaching out to Pyle's customer support directly. They should be able to provide you with the correct passcode or guide you through the pairing process for your Pyle Hybrid Amplifier P2002ABTI.
