I bought a cheaper version of epson ink cartridges (t1281,t1282,t1283,t1284) i bought a pack of 12, the first four worked perfectly and now im on the second four, the pink and yellow seem to be working but the blue and black keep coming up as unrecognizable, is there anyway I can fix this?
The problem with generic print cartridges are they are hit and miss. Every time you replace a cartridge ideally you should replace the print head with a new one ( little metal connector on the cartridge). When using a generic cartridge the print head isn't new nor original and the printer may realise this depending on the print head condition.
another point to watch is, using generic cartridges void your printer warranty, assuming its in warranty. Generic cartridges are a quick fix but not reliable.
SOURCE: I Have a Brother MFC-640CW
press menu then start bk copy then fourtimes arrow-up quickly after another. machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-bk-copy).
Machine will do some refreshing of ink and some special cleaning.
When finished press 7-6-3 start-bk copy
machine will do a power purge.
leave maintenance mode by pressing 9-9.
do run a test print.
DO USE ORIGINAL BROTHER INK or skyhorse generic ink only due to the fact that other generic ink will defenetly do damage to the printer!
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
SOURCE: Ink cartridges not working in epson sx100 all in one printer
hi.make sure there is no tape or dirt on cartridge chip contacts.if still no joy trying iserting one cartridge at a time then installing.say insert black then will say others carts missing red blue yellow.keep going till they are installed.sometimes helps.make sure the carts have lastest chips installed version 5 or higher if compatable cart.should not be a problem if bought from epson.eg t711 etc will fit but must be new carts with new chip otherwise may not accept.i belive the sx100 has something like t811 or something.this may be the new chip.otherwise may just be a faulty chip on the cart.you can get refillable carts or ciss system on ebay you put in your own ink.they are brillant.cart chips reset when low ink.hope this may help.
SOURCE: Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through
the motions of the printing process, kind of stands still with indicator lights
just blinking away. This could be as a result of either of these scenarios.
i.
Ink cartridge
has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink
is finished. You must replace cartridge one at a time). If lights stop blinking
it confirms that your cartridge has become incompatible or developed
incompatibility. Also if your printer is the type that can work with only one
cartridge, remove one after the other (closing back the lid/cover) to determine
which in the set (black or color) has become incompatible. At the instance the
incompatible one is removed and you close the lid, the blinking will stop (for
printers that can print with one ink cartridge only). Just replace the
incompatible one and start printing again. In most cases the issue is always
with one cartridge. But if both are affected, you have to replace both. Because
of this type of problem, always keep used cartridges somewhere safe; they come
in handy for this type of troubleshooting.
ii.
The Cartridge
electronic panel is dirty
The electronic panel on the cartridge that makes contact with the
cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the
cartridge with copper “dots”.
The
Solution is to try to clean this panel with a piece of folded tissue paper
soaked in a bit of methylated spirit. Also try to clean the area in the
cartridge carrier/holder that makes contact with the cartridge’s electronic
panel (Usually this is more difficult). If you cannot reach it with your
fingers, use a stick or something with tissue wrapped around it. Allow to dry
well and return the cartridges, close the cover. The blinking should stop if
the electronic panel is the issue. Once the blinking stops the printer will
print.
The chip contacts in the ink cartridge holder (cartridges removed)
