Go to www [dot] java [dot] com and run the test for "do I have JAVA." Let the site install Java for you if you discover your version is missing or out-of-date. Best to go straight to the source to get the JAVA! This will also install the automatic check & update monitor option so that your JAVA is always the latest & greatest! Do a virus and malware scan to be sure that some nefarious rogue demon isn't interfering with or removing your JAVA! This has been known to happen.
Java does not do the downloading. Downloading is done by your browser. After the program downloads, then try and install. Java may not be new enough to support Frostwire. Go to here and get the latest version. You can also check your Java and make sure it is running correctly here as well.
you need to do both for optim performance it's safe so enable Java(if you do not have it just download from sun website) and download flash player and instal it.
If you select downloads, your phone will try to connect to the Wap (Internet) service. If you haven't set it up with the settings to go online it wont work.
Settings are sent to you through a text message by your service provider.
