The dishwasher will drain and then fill with water. The pump motor starts and runs for one minute then stops for three minutes and will then run for one or two more. It continues to do this for the remainder of the cycle. The tablet will drop but will not melt completely and the sanitize light will not be on when finished. Dishes may or may not be clean because they get rinsed by hand before entering the dishwasher.
Hi Bill, this is AP
Based on the symptoms you are describing on how your Frigidaire dishwasher, model PLD2850, is performing I would think that your dishwashers control board could be causing this to happen. Your dishwasher should wash without stopping for longer periods of time. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
If needed you may use the link below to locate a local authorized technician.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Thanks,
SOURCE: my dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
SOURCE: Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element
Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan
Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat
Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
SOURCE: I have frigidaire dishwasher,starts cycle,can hear
Depending on your dishwasher, it fills either by a timer or by a water probe or float. I will assume its a timer as a probe or float wouldnt exhibit this behaviour. I would say you have a restriction in your water supply line. Check your valves, any screen filter in the water line for sand/scale/silicate/etc, pressure regulator if applicable. Another posibility is a poor magnet in your fill valve.
SOURCE: Dishwasher not running.
Sounds like the unit is either clogged, or the timer has an issue. Clean the unit, make sure the door latch is working properly and then go from there.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
