I need to watch video on installing distributor cap on 91 s-10 v6 4.3
SOURCE: distributor cap firing order 1993 chevy cheyenne truck v6
Firing order is 1-6-5-4-3-2 cyls. # 1-3-5 on drivers side front to back and cyls. # 2-4-6 passenger side front to back.
SOURCE: distributor cap and rotor location on chevy silverado
Most chevy 5.3 do not use a cap and rotor. Most have single coil per spark plug and wire. Trace spark plug wires to coil usually above the valve cover.
SOURCE: 91 honda civic dx. Starts, runs for a few seconds then stalls
Try pounding on the gas tank with a rubber mallet or similar tool. (careful not to dent the tank) Try starting it. If it runs, replace the fuel pump (it's nfg). I've diagnosed numerous fuel pumps this way. Remember the pump needs to be replaced, if you drive it, you don't know when it'll fail for good. Hope this helps. Please post the results.
SOURCE: 91 chevy caprice classic, engine hesitates
Check your fuel filter and air filter. That is usually where your hesitation starts.
SOURCE: how to install a distributor cap and rotor on a 1985 chevy truck?
I have had good luck with Echlin caps and rotors that are from NAPA.
You are going to need to mark your spark plug wires so you can get them back on the new cap in the right place. Tape with numbers on it or what ever you can come up with. There should be 4 screws around the lower part of the cap. Take your screwdriver and push down on the screw and turn like a quarter turn counter clockwise and you will see it release from the distributor. If you look at the new cap you will be able to see how it works. Once you have the cap off you will have to transfer the coil to the new cap. There should be 2 small screws on the top of the cap that hold the cover over the coil.
I think there are 4 screws holding the coil in to the cap and you will have to pull the wires and terminals out of the cap as you are removing the coil. Be careful when you retighten the screws in new cap.
When you replace the rotor you will see by looking at the bottom of it that it can only fit one way and lock on to distributor.
Just take your time. If you have any problems I will try to help.
