Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002 Logo
w
wilie bain Posted on Mar 13, 2014
The right front low beam not working and the left tail light not working all dulbs and fues are good what can i do
The right front low beam not working and the left tail light not working all bulbs and fuse are good what can i do
Jerry Weaver
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 88 Answers
  • Posted on Mar 15, 2014
Jerry Weaver
Contributor
Level 1:
New Friend:
Cheetah:
Answers
88
Questions
Helped
19730
Points
91
Check ground wires first. test to see if there is power going to the light sockets a simple volt meter should work to test with . if there is power going to the socket then its a ground issue. if not then its in the head light switch itself
In a 2001 Audi A4 with a 2.8L engine, how to fix no power to radio, climate control, and fog lights
Ck the fuses here is the info if you already haven't.
1-Headlight washer jets
2-Turn signal flasher
3-Headlight washer, glove box light, engine bay light, instrument cluster
4-License plate lights
5-Instrument cluster, heated seats, auto trans display, outside air temp
6-Central locking system
7-ABS
8-empty
9-heated mirrors
10-empty
11-cruise control(auto trans)
12-on board diagnostic system
13-brake lights
14-interior lights
15-power windows, climate control
16-ABS, anti-slip(?)
17-heated door locks
18-right high beam
19-left high beam
20-right low beam
21-left low beam
22-tail and side marker (right)
23-tail and side marker (left)
24-wipers and washer jets
25-blower for heating/climate control
26-rear window defogger
27-empty
28-fuel pump
29-engine timing
30-sunroof
31-tail lights, cruise control, auto trans
32-engine timing
33-cig lighter
34-engine timing
35-trailer receptacle(?)
36-fog lights
37-radio
38-trunk light, central locking system
39-flashers
40-horn
41-empty
42-empty
43-heated seats
Ok there's the numbers. To figure out what the hell that means you have to look at the inside of the cover to the fuse box. left side of dash panel. Good luck.
No headlights on dim only work on bright
old post.(day)
low beams, they are.
both low beam lamps.dead but are PARK/tail dead too?. (a key fact needed here to save time finding cause)
there are more that one cause.
but fuses are first, some cars have 2 fuse.
one for highs and lows.
or for left and right.
they do that so at least some lights work and not all go out at once, on a dark rainy night on a country road (or cliff road)
GEO, the car brand GEO is sold mostly in USA and Canada
if in CANADA the law says its DRL lamps.
in canada they have a Drylight Running lamps and laws and have a unique controller for that (DRL module) and can fail and mess up lamps. so GOT DRL>?
on this car the fues box shows, left and right HL
the next question is does it run a relay.
answer,
DRL, the DRL module runs low beams totally so that be first.
and its DRL relay.
non DLR metro, works like this
im reading the online schematics for you, and so could you.
the no-DRL is brutally simple.
the fuse runs the lamps direct, means lamps hot all the time.
the park and head light switch, grounds the low beam wire feed.
no relays , magic , DRL just a simple switch, in the combo switch.
for you or others seaching Metro head lamps.
here is the schemo.
red/wht wire must be 0v on low beams if not switch bad.
if g200 is good, but g200 is used in highs so can NOT BE BAD.
as you can see the switch grounds the HL lines below.
to make the lamps GLOW,
23880969-flsdwf0rx41rbdaez4cmhnol-2-0.jpg good luck to metros
Honda CR-V 2005 low beam out while the bulb and fuse are still OK
both LOW BEAMS (you make this so hard not saying that...)
but challenging.....
is car in canada, or usa? or a?
does car have DRL. we dont know ,until you say.
and both types work different, non- and DRL.
my answer (roll dice, ) USA. no DRL
the system is simple (alldata.com)
2 fues, left and right
2 relays, one left, one right.
1 controller box.
1 switch combo.
the sequence of events
HL switch on,
this ground the Low pin on the mutiplex control box in fuse box.
this box sends 2 ground signals to both relays.
so if one headlight works you know the mpx box works
both relays close
and 12v is sent to both low beams , and there other side is grounded full time so they glow.
there are 2 fuse left and right. fuse #15 and 17
Timp module dodge ram 1500
I put aftermarket tail light and headlights LED in my in my truck 06 Dodge Ram 1500 turn signals got hyper flash trying to replace the relay cannot find
2answers
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
lighting, mirror switches and actuators, airbag
warning light, outside temperature indicator,
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
39helpful
2answers
Need a fuse box diagram for a 1998 jetta
heres a diagram of the fuse box and i listed the fuses numbered 1-22,hope this helps.
1)low beam light left
2)low beam right
3)park lights.
4)reawiper/washer
5)front wiper
6)blower motor/ac
7)tail light right
8)tail light left
9)rear defogger
10)fog lights
11)high beam Left
12)highbeam rt
13)horn
14)backup lights
15engine electronics
16)sunroof/frt map/reading light
17)hazard lights
18)fuelpump /o2 sensors /control module
19)cooling fan, ac relay
20)brake lights
21)inside lights,clock,luggage light
Both front power windows stopped working
hope this helps. if u have any other questions just let me know
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1 - Headlight, Low Beam, Left (56b) 10
2 - Headlight, Low Beam, Right (56b) 10
3 - License Plate Lights (5icon_cool.gif 10
4 - Rear Window Wiper And Washer System 15
5 - Windshield Wiper/Washer 15
6 - Fresh Air Blower, A/C (X) 20
7 - Tail Lights, Right (58R) 10
8 - Tail Lights, Left (58L) 10
9 - Rear Window Defogger 20
10 - Fog Lights 15
11 - Headlight, High Beam, Left (56a) 10
12 - Headlight, High Beam, Right (56a) 10
13 - Horn (15) 10
14 - Back-Up Lights 10
15 - Engine Electronics (15) 10
16 - Power Sunroof, Front Map/Reading Light 15
17 - Emergency Flashers (15) 10
18 - Fuel Pump (FP), Heated Oxygen Sensor (HO2S)
Control Module 20
19 - Coolant Fan, A/C Relay (30) 30
20 - Brake Lights (30) 10
21 - Interior Lights, Clock, Luggage Compartment
Light (30) 15
22 - Cigarette Lighter, Radio, Luggage Compartment
Release 10
Separate Fuses
(Located above the relays)
- Fuse for ABS hydraulic pump relay 30
- Fuse for ABS main relay 30
- Fuse for A/C 30
- Fuse for power windows 20
- Fuse for cruise control 5
- Fuse for cigarette lighter 15
1helpful
2answers
2004 Outback: headlights stopped working.
either the headlight switch is defective or the dimmer is, it can't be anything else, do the hi beams work ok, have you tried wiggling the dimmer switch to see if the low beams flicker?
2answers
Dashboard, right side headlight and tail lights are not working
All My lights work the dashlights, headlights, tail lights, turn signals and revers, but not my right side running lights the left side works???
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
