Verify ur fuses located under the steering wheel. The cover for the fuses tells u what each fuse is for.
Then verfiy the bulbs if they are burnt. If ur healdight is burnt, when u replace it DO NOT PUT UR HANDS ON THE NEW BULB LENSE. They are halogen and do not like fingerprints.
For ur tail light, if this doesn't help lemme know and i'll tell u what else to check.
For the headlights, each headlight has it's own fuse. Left, right, high beams and low beams (which are also running lights if i remember)
Good luck hope this helps.
All My lights work the dashlights, headlights, tail lights, turn signals and revers, but not my right side running lights the left side works???
SOURCE: There are two wherle flasher boxes mounted under
Sounds like some wires may be crossed. Has anyone messed with the wires at all?
All my lights work the dash headlight tail lights but not the right side running lights and the fog lights ????
