My tv is not turning on. Just clicks and clicks. I understand either power board supply or I have been told capacitor. I would like to replace the capacitors, just don't know part numbers. Thanks
My Laptop HP computer. New. When Ever A Click On Youtube to view A Artist and Song, It sometimes tells me an Error has Occurred and can't play the Video. Why?? I've tried every thing I know how to do. I am Older man and not well versed on all this computer Jargon. All I want to do is listen to music. Can you help me with this I believe is not A big Problem,
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Testimonial: "Great fix"
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
SOURCE: Samsung TV clicking and won't come on
Did you find out if that would solve the problem? I was really excited to learn that all I needed to do was change out the capacitors but after installing 4 it continued to click. I to removed the cover to the and found the relay where the noise is coming from
