Use a bbe 882i sonic maximizer,have an old numark mixer,it worked fine from right and left
SOURCE: im try'n to hook a
Use four (4) TRS cables. Connect from the
AUX "send" (left and right) to the input of the effects unit with two of the cables. Use the other two cables to connect from teh effects out jacks to the AUX "returns" left and right.
SOURCE: Setting up a Behringer PMP5000
You can do the effect via the "POWER AMP INSERT" jacks.
Use TRS interconnects to yout effects unit.
If the effects unit does not have TRS type bi-directional in/out ports, you MAY need to make special cables to connect the units. Refer to figure 4.5 on page 9 of your PMP5000 user manual for INSERT connections.
SOURCE: berhinger acx 1000, power on, no sound amp not
Just had the baby brother (ACX450) with this problem...opened the amp... screws from sides and or top (including 2 hidden under handle covers).
The power cable from the power transformer had come off the connector on the circuit board in spite of goo they had put on it. Put connector back on and secured the cable and works perfect,
Since your display lights, yours is likely a different problem. I have also seen similar ones that the cable to the speaker had been pulled off its connection on the circuit board, rendering no sound. See if you have sound at headphone jack. and if none, how about the preamp output jack? Note you will only hear the left side using earphones as these jacks are monaural.
Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
