Panasonic HDD Navigation CN-HDS700D Logo
r
roberta waldo Posted on Feb 24, 2014
Power cuts out and starts again
It's in Japanese however screen freezes then power cuts out and starts up again
David Maha
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Jul 24, 2014
David Maha
Contributor
Level 1:
New Friend:
Answers
34
Questions
Helped
48286
Points
84
Electrorama Electronics Trinidad will fix that problem on your Panasonic Strada deck system ,It will remain on all the time it will stop going off and on and freeze up...Ph.662-6387 David or Daniel.They also convert radio station to receive local FM stations..
My Panasonic Strada CN-HDS620D Car radio/dvd only plays for 50 seconds then freezes for over 5 minutes. Buttons also freeze and it's in japanese. Kindly assist.
It seems like you're encountering some issues with your Panasonic Strada CN-HDS620D car radio/DVD player. The freezing and button unresponsiveness, along with the language being set to Japanese, can be frustrating. Here are a few steps you can try to troubleshoot the problem: 1. Reset the device: Look for a small reset button on the front panel or the side of the device. You can use a small pin or paperclip to press and hold the reset button for a few seconds. This will reset the device to its factory settings. Note that this will erase any customized settings or saved data. 2. Check the disc: Make sure the DVD disc you are using is clean and free from scratches or dirt. A damaged or dirty disc can cause playback issues. Try cleaning the disc gently with a soft, lint-free cloth and insert it again to see if the freezing issue persists. 3. Check the power supply: Ensure that the car radio/DVD player is receiving a stable power supply. Check the wiring and connections to make sure they are secure and not loose. If the power supply is unstable, it can cause the device to freeze or malfunction. 4. Language settings: If the device is set to Japanese and you're not familiar with the language, you can try changing the language settings. Look for an "Options" or "Settings" menu on the device's display. Navigate through the menus to find the language settings and change it to your preferred language. If the above steps don't resolve the issue, it's recommended to consult the user manual for specific troubleshooting steps or contact Panasonic customer support for further assistance. They may be able to provide additional guidance or recommend a professional service center if needed. I hope these suggestions help you resolve the freezing and language issue with your Panasonic Strada CN-HDS620D car radio/DVD player. Let me know if you have any further questions or need more assistance!
Panasonic Strada CN-HDS700TD, SCREEN frozen and can't do anything. Help? Also anyway I can change to English?
To unfreeze it, you need to cut the power for 5 minutes by removing the inline fuse. (for Randy from 2016 :)
Many of these units are for the Japanese home market and only come in Japanese. Use the Google Translate app Camera feature on a smartphone. Look for Settings -Language. (for Paul)
These videos may help
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00C-NdfU-1pTkm5qFyk4EsiRts4Sw%3A1609372412406&ei=_BLtX5auGKeRggeim5-4Aw&q=panasonic+cn-hds635d+change+language
Infinit m35 navigation system cutting out
Without knowing too much about this particular unit, I'll make one suggestion. When it does work, see if you can find a reset option in your setup options.
I have a Toshiba Portege M400. It runs ok if I leave it on a flat surface. However, if I try to move it the screen freezes up and the fan starts running very loudly. I am unable to do anything except cut...
Sounds like there might be dust inside of the laptop that is blocking one of the air vents. Plus the connectors to the screen may need to be reseated so that way the screen can be moved freely without it locking up on you and cutting off.
You have two issues going on. Bring it to somebody so they can open it up and make sure the air vents are cleaned out. Also they need to make sure the CPU fan is running properly. Then with the screen the connectors need to be reseated. Its also quite possible the screen connector might need to be replaced.
If the laptop is under warranty see if Toshiba will reapir it.
Subaru RS 1989 cuts off while driving
you should replace fuel filter unless it has been done very recently?
6helpful
2answers
16" gas chain saw loses power and stalls
you will need to clean the carb and put new gaskets in it. Make sure it has clean thin oil. Dont over due it on the oil
Mar 31, 2009 • Garden
Computer freezes on start-up
whenever your doing a cd recovery you need to remove the battery
use ac power
if its still freezing up you'll have to run windows again
Windows uses a lot of power to install
2answers
My god of war 2 constantly freezes
Dude atleast ur game starts my game doesnt even START!!!!!!!!!!!!
Kyocera kx2
i know its been long since uve post this did u try plugging it in and lettin that turn it on then hitting the power its worked for me when it has frozen on me
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
