It seems like you're encountering some issues with your Panasonic Strada CN-HDS620D car radio/DVD player. The freezing and button unresponsiveness, along with the language being set to Japanese, can be frustrating. Here are a few steps you can try to troubleshoot the problem: 1. Reset the device: Look for a small reset button on the front panel or the side of the device. You can use a small pin or paperclip to press and hold the reset button for a few seconds. This will reset the device to its factory settings. Note that this will erase any customized settings or saved data. 2. Check the disc: Make sure the DVD disc you are using is clean and free from scratches or dirt. A damaged or dirty disc can cause playback issues. Try cleaning the disc gently with a soft, lint-free cloth and insert it again to see if the freezing issue persists. 3. Check the power supply: Ensure that the car radio/DVD player is receiving a stable power supply. Check the wiring and connections to make sure they are secure and not loose. If the power supply is unstable, it can cause the device to freeze or malfunction. 4. Language settings: If the device is set to Japanese and you're not familiar with the language, you can try changing the language settings. Look for an "Options" or "Settings" menu on the device's display. Navigate through the menus to find the language settings and change it to your preferred language. If the above steps don't resolve the issue, it's recommended to consult the user manual for specific troubleshooting steps or contact Panasonic customer support for further assistance. They may be able to provide additional guidance or recommend a professional service center if needed. I hope these suggestions help you resolve the freezing and language issue with your Panasonic Strada CN-HDS620D car radio/DVD player. Let me know if you have any further questions or need more assistance!
SOURCE: recorded DVD disc freezes up on a different DVD player
hey ,
recommendation, the disc may have an internal scratch. (meaning when its played there might be a bump or something on it unseen by the human eye)
or you can stop being cheap. and get a new one
SOURCE: DVDs freeze every few seconds while playing
this could be from a number of issues. first is it a home made disk? second the type of changer you are using?
home made disks can be fixed by using a + or - disk depending on the disk and what the drive likes.
as for the second issue it could be a cooling issue or the lens might be dirty try blowing it out with some can air and try to use a lens cleaner disk. they should be able to sell one for about $5 - $10
SOURCE: Panasonic Strada CN-DV155, currently in Japanese
no it cant, i have the same thing and have been down that path. it requires navigation DVD's of NZ maps which are proprietary to that japanese gps system and they do not exist
SOURCE: I bought a mercedes car
Hi, i will like you to understand that just like American Spec. cars comes are installed with English language, so also are German Spec. cars come with installed German language and Chinese Spec. car too with the Chinese language.
So in this case, as long as the Mercedes car is of Japanese Spec., everything about it will be in Japanese and you cannot change the language except you get the English user manual of the DVD player or change the DVD player..
SOURCE: Am I able to install English onto my Panasonic
No, that model was never intended for use outside of Japan.
Either remove it and replace it with another system or ignore it and buy a standalone satnav system (always cheaper and easier to update/replace).
