My Quinny speedi sx unfolds with the seat frame upside down, How do I get it the right way round?
Hi Sheila
Not quite sure how or why this would happen. Please could you make contact with us via the Quinny Facebook page and we will be able to assist further.
Quinny
SOURCE: Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
SOURCE: Quinny Speedi SX backrest
i got fed up of my little one getting annoyed because he wanted to sit up and the buggy wouldnt !! so i brought a luggage strap fixed it behind the seat around frame and cliped it together,seat goes upright, you can still vary the incline of the seat and take off when not needed! PROBLEM SOLVED! XX
SOURCE: How do you attatch the dreami carrycot to the
Try this web link, it will take you to the owners manual that you can view or print out and show you the answer to your question.
http://quinnybaby.com/info_instructions.asp
Hope this helps, DutchTexan
SOURCE: Quinny Speedi sx replacement seat unit and hood
you can get replacement seats & hoods from quinny.com they are really helpful, seat is £65.00 Hood £35.00 hope this helps
SOURCE: How to I collase a quinny speedi sx pushchair
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know. HTH
