. Indicators still working, but no headlights, side lights or rear lights only on the right hand side. Any ideas? I've checked the fuses, but all look OK.
Blown fuse: I'm not sure the number but check fuse 12/22 in glove compartment's fuse box and replace them. I had the same problem and resolved it by replacing fuse.
Check ground and 12v supply for all the affected bulbs. Check fuse with proper test light. Is there a separate relay for right and left lights?
If there is, try switching them.
SOURCE: dipped headlights(both)not working on peugeot
Check the ground out to make sure its ok, are your headlights perhaps burned out ?
SOURCE: "when do i change the cam belt on a peugeot 307 sw diesel"
usually you should do it for peugeot diesel at 122000 miles along with water pump and the tensioner roller that runs under the cambelt too. But to be on the safe side do it at 100000 and save the fortune.
It took me (DIY job) about 6-8 hours as i wanted to save 450 pounds.
SOURCE: Peugeot 307 2.0 hdi. Hard to steer. ESP light
it sounds like your electric power steering pump has gone. if the esp light is on then it means it has recorded a fault in the electrical stability program system and may need to be plugged in to read codes, the fault may refer to a fauly wheel speed sensor
SOURCE: The brake lights on my Peugeot 307 have stopped
tour car requires a brakelight switch, u can find the switch under the glovebox.
