SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Testimonial: "very helpful"
SOURCE: I have a braun 5614 razor bought in usa many years
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
SOURCE: braun 5614 battery replacement. where
You will find replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
Start by removing the foil and cutter. To open the shaver body, start by removing the two round screw covers on the bottom by prying them out. Then remove screws. The insides of the shaver can then be slid out through the top. Batteries simply unsnap from their connectors. Install new batteries and reassemble in reverse order
SOURCE: I have a Braun Flex
You will find the correct batteries for model 5614 at shaveroutlet.com. See link below
To open shaver, first remove the two round or oval screw covers on the bottom of the shaver. Then remove the screws underneath, The can then slide the outer case of the shaver down and off of the shaver inner body exposing the batteries
SOURCE: How to reduce Braun 5614 shaver noise? Foil and
If you are experiencing unusual noise, most likely, the swivel frame that the foil and cutter fits onto is broken inside. This causes vibration and excessive noise.
If this is the problem, you will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7030220-swivel-foil-frame-p-810.html
Testimonial: "I'll try the suggested solution, thanks"
