Question about Braun Flex XP 5614 Electric Shaver
Braun 5614 battery replacement. where to obtain battery, and how to open shaver to replace it.
Posted by jameslweiss on
Donald
    New Friend:
On amazon you can find battery + kit for replacement, take a look here: HQRP 2 Pack Batteries for Braun Flex XP Model 5663 Type 5720 Razor Shaver... . I hope this was helpful. cheers
braun 5614 battery replacement. where - braun-5614-battery-replacement-xwjejeojs5eomijdevgtyecs-3-0.jpg
Posted on Dec 15, 2014
shaveroutlet.com
  • Braun Master
  • 1,645 Answers
You will find replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
Start by removing the foil and cutter. To open the shaver body, start by removing the two round screw covers on the bottom by prying them out. Then remove screws. The insides of the shaver can then be slid out through the top. Batteries simply unsnap from their connectors. Install new batteries and reassemble in reverse order
Posted on Oct 20, 2010
1helpful
1helpful
How to reduce Braun 5614 shaver noise? Foil and cutter have been replaced and are regularly cleaned and lubricated with Braun products
If you are experiencing unusual noise, most likely, the swivel frame that the foil and cutter fits onto is broken inside. This causes vibration and excessive noise.
If this is the problem, you will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7030220-swivel-foil-frame-p-810.html
Battery
you will find the correct battery type for model 5614 at shaveroutlet.com. See link below
I have a Braun Flex XP 5614. It´s some years now, and I have to charge almost every second day. I thought it would be smart to change the batteries, but how? I have removed the two screwes, but I...
You will find the correct batteries for model 5614 at shaveroutlet.com. See link below
To open shaver, first remove the two round or oval screw covers on the bottom of the shaver. Then remove the screws underneath, The can then slide the outer case of the shaver down and off of the shaver inner body exposing the batteries
1helpful
Hello, I have had a Braun 5564U model shaver for years. I used in up till last week when it quit running altogether. At that point, the led light will also not illuminate and the unit does nothing. I...
Most likely, you have damaged the circuit board from using it directly from the cord for so long and not changing the batteries when they were needed. The fact that the chatging light no longer illuminates tells me that this is probably the case. However, it is possible that only the batteries are bad. It is pretty hard to tell which it is without installing new batteries though. If you want to try new batteries, you will find the correct type at shaveroutlet.com.
If your unit has two batteries, order two of the type linked below
http://shaveroutlet.com/shaver-replacement-parts/batteries/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If yours has only one battery, you need this type:
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-replacement-battery-aa-nimh-p-108.html
I have a braun 5564 electric shaver i think the battery is dead can i get a new one and how do i replace it
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
I have a braun 5614 razor bought in usa many years ago and now needs new batteries.No one in zimbabwe can help, please tell me how to open razor and change batteries.
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
4helpful
Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Braun Flex XP 5614 Electric Shaver Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
reference30
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
