The 3 beeping sound as ou call it annoying means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
It definitely is a matter of the lens. I am having the same problem and after reading your posts here tried playing with the lens and got it to turn on but the lens remains defective. I need to find a fix before i go on my trip to Guatemala in a week!
It means that the camera is having issues with the zoom and the lens moving outward. Usually the case is that something is stuck between the different levels of the retractable zoom. After it beeps, try pulling the outermost rim of the zoom out a bit, then pressing the power button again.
Just an update, sent the camera out for repairs. Nope batteries were not the issue at all, it was caused by a defective zoom.
A lot of ppl are facing this prob, seems common with all dig cams. try using rechargable batteries even i have the same prob diff model .
Your batteries are dead.
I turned off my camera and then when i tryed to turn back on and the camera came out a little and then beeped three times and went off. i tryed new batteries and it still didnt work.
Camera will not turn on all the time.. Works roughly once a day. When I press the on button, the green light comes on, but then it beeps 3 times and turns off. It is not the batteries as I have used 3 different sets of new lithium batteries, and as I mentioned, it will work every now and then. Any help would be great appreciated.
I have digimax A7 and have the same problem.
3 beeps and the camera goes off again.
I has tried new batteries and it dosent help!
yes I have the same exact problem. I don't see much good at this site.
I hope some one finds out the problem.
light beep, then off
