Where can I find a new or rebuilt power supply for a RP 3700?
SOURCE: master wont ink up on riso 3700, How do I check ink pump and test
This is unlikely that the pump is not working.. I have 2 RP 3700s.. The screens are probably clogged.. with old ink.. or there could be a fit problem with the ink tube to the drum.. (no vacuum). With the drum in the machine and the ink in installed.. Take handle of a hammer and lightly (LIGHTLY!) push to ensure that there is no air pocket in the ink tube.. Carefull not to push too hard and squirt ink all over inside the machine. Also ink screens can be taken off and cleaned with varsol and re-installed.. Also as a final check.. make sure you are makeing a master.. look closely to see if you have a lazer burned image on your master.
SOURCE: Riso RP 3700 indicates that the master is still on
It honestly sounds like the unit is going to need some repair work. All the types of troubleshooting possible have been done by the looks of it. It's a hardware problem which is impossible to repair remotely.
You can call Riso at 978-777-7377 to find the nearest service center.
Sorry about that.
Thanks for your patience and understanding,
Tim
SOURCE: I have a Riso RP 3700 and I changed a drum from
I've read a little about flushing drums with solvent or even gasoline or diesel google it a little see how people have done it. though I can imagine a Switch from a dark to light colour might be impossible. You could pull the screen off and wash it out. Some ideas. No solutions.
SOURCE: i have a problem withz riso rp 3105 ep
Many people have an problem. Some people have a solution.
To provide a solution you have to describe your problem!(Simple, but the hard truth. Must I be sorry for the clear words?)
