Pilot light will light. but when you release the button the light goes off. i installed a new thermopile. the first time I lit it it worked. the next time it would not stay lit.
SOURCE: star deep fryer.
Those thermostat bulbs are the thermostat and hi-limit bulbs.They need to be secured to the fryer.The hi limit is tripping out because its sensing that the oil is too hot.Even though the oil isnt that hot the hi limit thinks it is.
SOURCE: fryer quits heating have to hit reset switch
This button should be a high limit switch. If it is a small red button mounted to a 2" x 2" or so device. You most likley have an issue with the thermostat letting it over heat. The best thing to do would be to replace both the thermostat and the high limit for safety reasons.
SOURCE: pilot does not stay lit
clean pilot light first , you may need to change thermopile or thermocouple see what mille volts you get from thermopile need 600mille volts
