20 Most Recent
Imperial IFS50 Deep Fryer Questions & Answers
Hi,i want to know wath is the oil's temperature
I would guess about 120-150F for the oil. There is a screw under a cap on the gas valve that you can use to regulate the pilot, but this is not recommended. The flame must be high enough to heat the thermopile sufficiently so that the pilot will stay on and the main valve actuate. For better or worse, most gas fryers are designed to keep solid shortning in a liquid state when off and to safely melt it overnight. If you need the oiler cooler, say for filtering, I suggest just turning off the pilot.
Comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
What is a hi-limit thermostat
Detects too-high temperature within the unit & opens a set of contacts to prevent further operation under high-temperature conditions.
Leaking
Imperial Catering. Elite House, Castle Business Park, Pavilion Way, Loughborough LE11 5GW
Reg. No.: 2449623 Copyright © 2007
Telephone: 01509 260 150
Fax: 01509 260 151
Imperial Fryer Pilot Won't Light IFS50
For sure if you got gas to the unit.The only thing to keep the pilot for working is hi limit,thermocouplen.One other thing is does this unit need power for it to work?
Thermostat broken
try this company i think they will ship anywhere ICS 1800 243 1290 ext 4226 ( Scott)
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Imperial IFS50
Hi, Probably the thermocouple. It will be right at the pilot light and hooks to the gas valve. The pilot heats it up to tell the gas valve that the pilot is working. If this is an electronic ignition, It will be the flame sensor still close to the pilot and will need cleaned or replaced. Hope this helps.
kstfas
Imperial Deep Fryer pilot won't stay lite
When the pilot goes out and won't stay lit is is usually because the Thermocouple safety device has failed.
The burners should never be on when the thermostat is off. That is incredibly dangerous. You need a gas registered service technician.
