Whirlpool RBS305PDS Electric Single Oven Logo
Posted on Oct 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool oven issue
My oven (Whirlpool mod#GY396LXPB00) will not bake, I think it's a control panel problem but I'm not sure.  The bake button does nothing!  The custom broil and self clean cycle both function. The door locks when you activate the self clean and works properly. It started acting up the other day, my wife tried to bake something and couldn't adjust the temp., when you push the bake button it starts at 350 automatically and then you adjust from there, well it would not adjust, the up and down keys didn't funtion. So we used the oven at 350 and then it wouldn't shut off, the off button didn't function, I had to go open the breaker to shut the oven off. When I reset the breaker (allowed time to cool) I had my current problem, no bake funtion at all. Any input or advice would be appreciated! THANKS
secondary question:  do both the top and bottom elements function on a self cleaning cycle? I let it run for about 5-10 min and only my top element worked.
  • Anonymous Dec 21, 2008
    I having the same problem, I cleaned my oven and now it sounds and looks like it is heating up according to the digital display, but nothing heats up the broiler nor the oven. Has there been a recall on this model from Whirpool?
  • geminikimr Dec 21, 2008
    I am having the same problem 5 days from Christmas cleaned the oven and now neither the broiler or the oven heat up.
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Oct 26, 2007
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512982
Points
14106
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
What is the purpose of the WLP83800 "AUTO" Oven Function?
If the button in question is on the top left of the control panel, this is for Automatic Convection Bake. This is the control panel picture, http://www.youserguide.com/wiki/Whirlpool_Use_and_Care_Guide_-_9782476-011 ; the word Convection is below the top pair of buttons with Auto to the left. Set the oven temperature to the regular setting for your food. The oven will reduce the temperature to the appropriate temperature for baking with the convection fan running. You do need to check the food more frequently. See http://www.youserguide.com/wiki/Whirlpool_Use_and_Care_Guide_-_9782476-016 .
I hope this helps.
Whirlpool accubake model WFG371LVS2. Set bake to 350, meter reads 465 before shutting off. Thermostat and control panel have been replaced. Is this a proper temp swing?
Could be oven temperature sensor.
https://www.searspartsdirect.com/part-number/W10181986/0022/664.html?modelNumber=WFG371LVS2&categoryName=Free%20Standing,%20Gas&brandName=WHIRLPOOL
We have a maytag oven. all the buttons work except for the bake and light button.Mod # umc5200aaw
only half of one side of the maytag oven touchpad control panel works, its one 2 yrs old help!
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. [email protected]
2answers
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
2answers
WHIRLPOOL GY396LXPB00 MIGRATION CONTROL PROBLEM
press and hold at the same time child lock ( 2nd button in the row of buttons under the clock. and cancel ( bottom button far right ) hold until lock light blinks (10 -25 sec) hope it helps
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
