SOURCE: my uniden bt108 bluetooth headset would not pair
On
your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
SOURCE: cannot pair my Emerson EM-227 wireless headset with my Iphone
Some headsets have a built in code not all are 0000 check your documentaion for both the phone and headset
SOURCE: pairing my Z9i v1.1 headset with my new iPhone
I had a problem with this also, try this.
Turn off both devices then turn on your phone.
make sure your bluetooth option is "ON" on your phone
turn on the blueant z9i
press and hold both volume buttons, while doing that, press the ANT button.
Your blueant should be flashing fast right now and your iphone should be able to find it.
complete the pairing by selecting the blueant headset on your iphone and enter the code "0000"
enjoy
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
SOURCE: trying to pair nokia x6 with nokia BH-214
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
