2006 Suzuki Grand Vitara Logo
A
Anonymous Posted on May 05, 2017
Grand vitara engine warning light
Hi, I have an 06 Suzuki G/Vitara, Diesel 1.9. Recently I've had the Injection Warning Light come up twice in 2 days which resulted in the engine being ******** and would not accelerate. I left the vehicle to stand with engine switched off for a while and when I started it up again the warning light had gone. For safety I took it to a local garage and they put the analyser on it. They said that there was no error log for this, it seemed as though the system had cleared it down. Any suggestions on how to correct this problem. Thks Steve
Bogdan Odwazny
Level 3:
  • Suzuki Master 6,171 Answers
  • Posted on May 05, 2017
Bogdan Odwazny
Suzuki Master
Level 3:
Answers
6171
Questions
8
Helped
1201640
Points
19890
Put seafoam for cleaning system go to auto zone they will tell you.
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 02, 2008
SOURCE: Prius series 1 (1998) warning sign
You will need to have this light reset with a scan tool, it is stored in a non-volatile (stays in memory with or without battery voltage) memory. Have the dealer check the cause, better than a tow bill.
Anonymous
  • 105 Answers
  • Posted on Jun 05, 2009
SOURCE: engine warning light stays on my suzuki grand
try disconnecting the batt for 20 mins.
Anonymous
  • 1986 Answers
  • Posted on Aug 13, 2009
SOURCE: P0340 CODE
check your timing chain and see if your engine has a tensioner as that may have failed. chain may be just a lil loose
Anonymous
  • 1776 Answers
  • Posted on Sep 06, 2009
SOURCE: engine management light on ,suzuki grand vitara 2
Take the car to an autoparts store and have them scan the computer for any fault codes stored. The check engine light is to alert you that the computer has noted a fault in one of the car's systems. Getting the codes will show what the computer has noted and curb the need for speculation. Most parts stores will perform the scan for free. Hope this helped and best wishes.
Anonymous
  • 1922 Answers
  • Posted on Nov 06, 2009
SOURCE: The Glow plug warning light on - Grand Vitara
your power relay supplying the glow plugs may be stuck(welded contacts)on and need replace
Testimonial: "Many thanks for the suggestion. Unfortunately relay seems fine. I think it may be an engine management problem."
Hi , I have a 2010 1.9 DDIS vitara . There is a warning light on the dash( rectangular box with a zig zag line through it ) and the engine has lost power , no turbo boost. Any ideas?
(in what country ,we are USA are you)
direct diesel injection system.
our books (pro) cover are cars,not others.. so.... where are you.?
the glove box has operators guide, and every lamp is covered.
read that yet:?
we cant see it unless you post a photo of it,
words dont convey how things look well a tall,
scan it yet , any time engine looses power we
check engine oil level
the coolant.
then scan it. 1,2,3, bingo
or why not get the car serviced as most do.?
the warning lamps vary by, engine, transmission and country
and laws in each country, regulation them.
the glove box book matches all that, so dont loose it ,
if lost buy one and not be stuck like this.
SUZUKI GRAND VITARA DIESEL LIGHT
THe cpu has read some parameters that are coming from all the sensors that it continually reads and found faults > have the codes read to find which sensor is failing
I have a 2008 Suzuki Grand Vitara with fault code p0468.
468(gasoline engine)EVAP Purge Flow Sensor Circuit High (loose gas cap?)
Diesel Particulate filters (DPF)
you have diesel?
state engine in car, there can be many and country,
Do i need lock tool to change cam belt on a 03 grand vitara
I'd be first confirming whether you have a 1.6 litre Grand Vitara (petrol), or a 2 litre turbo diesel. The 2 litre petrol (straight 4 or V6) or 2.5 litre petrol engines are all chain drive.
If your engine is petrol then no lock tool is required (to hold the camshaft). Of course, there is a specific position that an engine should be rotated too before removing the belt from ANY engine.
If it's diesel, then although I'm unfamilar with that particular engine, the general requirement for diesel engines with high pressure injection pumps is "yes, you require a lock tool" to hold the injection pump pulley. As I think these are a common rail set-up, this requirement may not be necessary. Check with your Suzuki Dealer, or maybe someone else here will know more. A similar question may have already been asked and answered here too.
1helpful
5helpful
2answers
Engine management light on ,suzuki grand vitara 2 litre turbo diesel,engine feels slugish
3helpful
3answers
Suzuki grand vitara RHZ Diesel auto/Diagnostic tool
my 1993 very recently aguired.Grand vitara deisel. has imoberlised it's self. have had guys up with computer diognostics and found it in safe mode.found fault on turbo charger fixed it..all go, went for a short run ..great turned it off and on twice all fine.....next morning it had imoberlised itself again guys came with computer no fault found.. but it still will not start....help please........
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
