SOURCE: DC440ST Network/Print controller
When it boots to 70 percent and faults out, one of 2 things.
If you look in the fault codes, or if one is displayed. If it is a 07-11 then you have a bad hard drive in the network area, or as Xerox refers to it as the ESS module, That is the most likely cause.
Secondly maybe the ESS software is corrupted and needs to be reloaded.
I more suspect the hard drive. It's not an uncommon failure.
SOURCE: missing first letter of each line printing to xerox dc440st
If it is only from one PC, then there must be a setting in your printer properties (right click on the printer, left click "Properties"), probably under 'printing preferences', then maybe "paper/quality" and or "finishing" (every printer is slighlty different). check theat the Zoom is set at 100% , and anything else that refers to size is correct....that's my best guess.
