Please check if there's a CD disk included when you purchased the Asus Monitor VL222H, wherein you can read the user guide from such CD disk. regardsPlease check if there's a CD disk included when you purchased the Asus Monitor VL222H, wherein you can read the user guide from such CD disk. regards
You can't post conmments that contain an email address.
Good choise, I have two of the VW series and one of the PG series of asus monitors myself, all doing great so far, the PG is atleast 2 years old soon, others are around one year.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
When I installed new or older drivers for my nvidia 9800gtx, my vertical refresh doesn't ... I would like to change these to the proper Nvidia drivers so I can have the control ...1. Download correct Nvidia drivers and save somewhere 2. Uninstall the GTS250 ....ASUS VK222H 22" widescreen LCD monitor (1680x1050) ..
Have U tried to install the latest videodriver ( from the vendor, not Microsoft).
How did U connect your screen? VGA? DVI? try and change these
Try to factory reset the screen and see what happens, i would do this in this sequence
Mine did the same. I don't know what caused it, but removing the menu button solved it. Crude but effective. I took a knife, pried out the Menu button, then took a pliers and removed the little black plastic button and problem solved. Now I can't change the settings, but switching between VGA, HDMI, and DVI works just fine. No more annoying brightness pop-ups that don't go away!!!
i would go to asus or computer manufacture's site, or microsoft and find and download the driver manually. Then install it by double-clicking the downlaoded driver file. I also recommend right clicking on screen, go to properties or display properties, and only use the windows 7 them and not a modified or customized theme.
