then you are ready to position your speakers if you have
more than 2 you might need to select stereo
Speakers can be
placed on floor stands, hung on wall brackets, or placed on furniture.
Subwoofers typically sound best in room corners or near the left- or
right-front speakers.
The front
three--left, center, and right--speakers usually sound best when positioned
with their tweeters elevated to the same height as a seated listener's ears. In
any case, try to keep the center speaker near the same height as the left and
right speakers.
You can place
speakers on shelves or on/in a low cabinet or entertainment center. Some
speakers are better suited to this arrangement than others. "Acoustic
suspension" sealed satellites are the most appropriate. Next best are
ported speakers--as long as the ports are located on the front of the cabinet.
However, speakers with rear-mounted ports won't perform at their peak when
placed inside a piece of furniture.
As for the
rear-channel surround speakers, they usually sound best when positioned three
or more feet higher than the front speakers. However, high-fidelity DVD-Audio
and Super Audio CD music will sound best when surround speakers are placed at
the same height (ear level) as the front speakers.
Hope this helps
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps
dont forget to vote
