SOURCE: computer shuts down watching netflix.........1/2
The most likely thing is that you need to adjust your power savings settings on the computer in Control Panel. Watching a movie doesn't register as "activity" to the system so if you are set to Sleep or Hibernate after an hour that would typically cut you off half way thorught the movie.
You can change the power savings settings or every 30-40 minutes move the mouse around or click the keyboard etc. to restart the timer.
SOURCE: can't watch netflix movies,vol too low
if its by internet and not CD, its prob cause netflix runs through sateillite and its reaching your computer slowly, and if your internet is bad it wont play that loud or be that clear
SOURCE: no sound through my vizio
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
SOURCE: I keep losing my netflix
use different outlet in the house do not use the same one which connected to air condition,it will draws more power from that output..
SOURCE: no sound on TV with hdmi cord
HI Mike,
Sometimes HDMI ports have their sound channel shared with the VGA/RCA port and they need to be switched around in the TV settings.
I dont know what is brand is your TV set so you will have to check yourself in the sound settings and also check for PC settings, see if you can change that around.
You can also just try another HDMI port on your TV that have the sound dedicated to it.
