Crosley CR247 Shelf System Logo
A
Anonymous Posted on Jan 15, 2014
Crosley cr247 schematics - Crosley CR247 Shelf System
2 Related Answers
  • 6688 Answers
  • Posted on Jun 04, 2011
SOURCE: need a user manuel for a Crosley#CR247 where can I
If you have the Crosley Composer CR247 CD recorder and turntable, the manual is available from the product page from Crosley: http://www.crosleyradio.com/Product.aspx?pid=1791 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR247_Manual.pdf .
I hope this helps.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Nov 07, 2016
SOURCE: Where can i buy a remote or order one for crosley cr247
http://www.remotes.com/product-p/crosley%20cr247.htm
How and where do i order a remote for my crosley cr247
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Schematic for cr248 turntabletu
Type " Crosley CR248 User Manual " in search engine and it will bring up sites to get manual. I'm pretty sure a wiring diagram is in user manual'
Need schematic for CR73. Only radio works.
I'd like to see the schematic/parts manual, too.
Crosley schematics
Thermal fuse inside the power transformer
2helpful
2answers
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim [email protected]
Crosley cr12-10 schematic
just purchased new 3 days ago. removed music cd from car to play in jukebox. would not play any disc 1-10. would keep on changing to next disc without playing.......help!
Need a user manuel for a Crosley#CR247 where can I find one?
I hope this helps.
2answers
I need the manual for crolsey player recorder model cr247-pa
Download from Google Exemple type on google .. (download Crolsey player model CR247-PA manual & drivers Then take the one you need good luck
1helpful
Crosley CR247 never used, sat for almost year, display :"OPEN"
seems you need to go to the spesific mode, fono, or radio mode.
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
