Question about Crosley Conductor CR73 Turntable
Need schematic for CR73. Only radio works.
I have a Crosley CR73. The turntable, CD & tape do not work. Only the radio works. A schematic would aid in my repairing it.
    New Friend:
  • 11 Answers
I'd like to see the schematic/parts manual, too.
Posted on Jan 14, 2016
6ya staff
SOURCE:
Steve W
  • 104 Answers
SOURCE: Getting the turnable to come on
some platters will not begin to spin until the tonearm is lifted up from the rest and over to where the record is, then it starts spinning.
alternately the belt may have come off.
http://www.archive.org/details/Turntable_Belt_Installation
will provide general info on how to put it back on.
Posted on Feb 11, 2009
Steve W
  • 104 Answers
SOURCE: The turntable for Crosley Radio CR66 will not work.
Posted on Feb 22, 2009
Anonymous
SOURCE: Turntable does not turn
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Posted on Aug 07, 2009
Jean Marie
  • 3 Answers
SOURCE: need new turtable for a Crosley CR24
Orderparts from Crosleyradio.com
Posted on Aug 09, 2009
Anonymous
  • 69 Answers
SOURCE: I always get static when adjusting the volume of
sounds like you have a dust build up on your volume switch? buy some electrical contact spray ( aerosol type ) remove the switch/knob........just pull it towards you, remove the knob and spray a bit......not too much and refit the knob and twiddle it about with the power off and then try it? repeat if necessary? good luck.
Posted on Oct 07, 2009
Where can I buy needle for cr73-3
These people can help. Be sure you get the right kind (LP or 78)... http://www.lpgear.com/product/CSYCR0073W.html
You can contact them here... http://www.lpgear.com/CTUS.html
Jul 08, 2014 | Crosley Conductor CR73 Turntable
I always get static when adjusting the volume of my Crosley CR73, and sometimes the volume doesn't change smoothly and sometimes, I think, one channel stops working completely.
Sep 27, 2009 | Crosley Conductor CR73 Turntable
Need new turtable for a Crosley CR24
Mar 01, 2009 | Crosley CR248 Turntable
Crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Dec 12, 2008 | Crosley Conductor CR73 Turntable
Turn table
Mine isn't working either, have you tried your speeds? I messed with mine and found out only the 78 speed works.
Dec 24, 2007 | Crosley Conductor CR73 Turntable
Crosley Conductor CR73 Turntable Logo
270 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
Gene Pitts
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
