Screeching when reversing and turning corners, find if i turn off lights and heating, screeching stops quicker than if lights are still on, would welcome any comments before i approach a garage.
SOURCE: Problem with 2006 Suzuki Swift GLX Air con
mm sounds like the air con is in need of an overhaul take it to someone who specialises in aircon to be checked out hope this helps you
SOURCE: had oil changed at first service as light was
Okay in your owners manual look up oil service light and it will give you a few steps on how to reset it this has to be done every time you change the oil and most mechanics should know how to do it except wal mart their not certified mechanics. But you can take it to any mechanic or say like a Jiffy Lube or who ever doe's oil changes like these guys and have then help you reset the light but it should tell you in the owners manual.
SOURCE: my 2007 suzuki forenza oil
How do I fix a 2005 Suzuki Forenza Engine Sludge, Oil light, Lifter Knocking Problem?
find the source first.
it can be something simple a loose or bad fan belt.
or sometimes very bad. like brake failures. These
symptoms can be very dangerous, get expert hands on help any time there is unusual noises. I'm sure.
sure its, but what if it not that.? , best is to get it checked by live mech.
Thank you for comments
its to do with the fanbelts check the AC belt
