Scanner is stuck on channel 2 will not work on manual Just stays on channel 2
SOURCE: scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
SOURCE: acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
SOURCE: scanner reads memory loss and is stuck on a police
This means that you have lost all of your programs all of your Frequencies are gone.You will to reprogram it.If you leave it unplugged for a long period of time it will do that.
