BSOD is not a good term to use. That term means that screen comes up WITH WHITE writing on it and it shows what the error was that caused the problem.. So if it is a true BSOD then what are the codes that show up?
Just because you get a BSOD message does not mean you have a virus. Granted if you have a virus this can cause problems with your system files which cause a BSOD.
The easiest way to clean your system would be to go to this link and run a scan on your computer.
However this still may not fix the BSOD issue. If you keep getting it please reply with the error message that is in the BSOD. The link below will show you what is needed if you are not sure. With the error message and stop code i can tell you where the problem is.
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
For nontechnical people who need a solution on how tofix the Blue Screen of Death,there is no simple answer to that. TheWindows operating system constantly refers to the registry to get informationabout all of the components such as hardware and software which are installedon the computer. The registry tells Windows what to do and how to access thevarious programs, files, and processes. However,the registry can contain bad information which sends Windows off doing uselesstasks or running unneeded routines. Sometimes errors occur including the bluescreen of death. Other times the system slows down. Because of the sheer numberof factors that can affect the registry, there’s no one size fits all approach.You can’t just go into the registry and remove the bad information because it’snearly impossible to decipher which information is good and which informationis bad. That’s a job better suited for software.
You can configure Windows to not automatically restart when a bsod occurs. In the Control Panel, go to System and then select the Advanced tab. Then click Settings under Startup and Recovery. Clear the Automatically restart checkbox.
Now when the bsod happens, it will stay until you power down the computer. You can read the STOP error of the bsod and any potential file name. Now you can search for the exact error and solution. This article on troubleshooting blue screen errors might help you further.
