20 Most Recent Seagate (ST320014A) (st320014a-25tpk) 20 GB Hard Drive Questions & Answers
Seagate hard drive model st320014a
Hi
Uninstall the Seagate Hard drive in the device manager and reboot your computer. By this case, let windows detect it.
I believe you are using Windows 7 64 bit which is causing problem.
If not solve, Just install Windows 7 32 bit and sure it will works.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
5/13/2011 6:28:14 PM • Seagate... • Answered on May 13, 2011
I own a dell optilex
dmacduff1443
Just because you get a BSOD message does not mean you have a virus. Granted if you have a virus this can cause problems with your system files which cause a BSOD.
The easiest way to clean your system would be to go to this link and run a scan on your computer.
http://housecall.trendmicro.com/
However this still may not fix the BSOD issue. If you keep getting it please reply with the error message that is in the BSOD. The link below will show you what is needed if you are not sure. With the error message and stop code i can tell you where the problem is.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
http://www.fixya.com/users/issken
2/3/2011 10:00:03 AM • Seagate... • Answered on Feb 03, 2011
ST320014A
There are no drivers needed for Hard Disk. Just install. Make sure your ide drives have correct jumper settings for master or slave- however you are configuring it.
Char S.
5/21/2009 9:59:22 PM • Seagate... • Answered on May 21, 2009
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
5answers
Need restore my RAW file system back to NTFS without losing any hard drive files?
There are two options for you to get your drive stuffs back right now: 1). Do not format this RAW file system external hard drive temporarily and plunge it to your PC. And then, choose and apply RAW external hard drive data recovery software to scan this drive and find your preferred drive files back as many as possible. 2). Directly consult some professional data recovery services from some data recovery companies or agencies. In the future, remember to save copies of everything important on at least two devices in case of any similar data loss issues.
1/5/2021 2:43:04 PM • Seagate... • Answered on Jan 05, 2021
I have seagate plugged in and attached to my computer. I downloaded the program but I get the message connect a dashboard enhanced drive to activate features ??
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible. Does the drive show up in the File Explorer / Finder of the machine?after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
10/20/2019 9:49:12 PM • Seagate... • Answered on Oct 20, 2019
Necesito controlador para Seagate medalist 4310
I need controller for (English please) in a computer,. or DVR or what, where does this HDD go? Medalist 4310 (ST34310A) built in 1999 (20 years old ) why use any drive this old. why? it's useless. my wild guess, is this you have a PC and ustated PC has SATA only ports (modern) and this old old HDD is PATA drive, with ribbon cable wide. and you think it can run on modern PC. well they do sell cards (PCI-e) that fit and work. 4.31GB is the size , holds about 1 top movie . are you going to boot from this drive, if yes, very complex answer I will skip here. (ask maker of card , if it can) newegg.com has them all, any thing you can dream of , is there. if you look. https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB8ZU9127&Description=pci-e%2c%20pata%20IDE%20card&cm_re=pci-e%2c_pata_IDE_card-_-17Z-0007-00AF2-_-Product again, no PC stated, no OS stated. nor of booting is needed to the PATA relic drive. from 1999.
4/8/2019 1:42:01 PM • Seagate... • Answered on Apr 08, 2019
4answers
Hi, I accidentally dropped my 2 tb Seagate expansion disc and now its making funny noises andm it wont even read on my windows 8 computer. Can some 1 help me please?
unfortunately it appears that the internals are shot if the funny noise is a clicking sound or squeal then the repair is a new hd unit as they are generally not repairable.
3/27/2019 9:36:59 AM • Seagate... • Answered on Mar 27, 2019
3answers
How to recover data from a dead Seagate external hard drive for beginners
Tutorial to recover data from dead Seagate external hard drive
Step 1: Download & install iBoysoft Data Recovery on your computer. Step 2: Connect the dead Seagate external hard drive to your computer. Step 3: Launch iBoysoft Data Recovery and choose the dead Seagate external hard drive. Step 4: Click "Next" to search for lost files on the dead Seagate external hard drive. Step 5: Preview the searching results. After that, select the lost data and click the "Recover" button to get them back. Step 6: Have a check to ensure all lost data have been recovered.
3/27/2019 3:00:21 AM • Seagate... • Answered on Mar 27, 2019
Seagate backup plus is beeping and will not pull up on computer?? Yes when i plug in my hard drive, nothing pops up, but hard drive is flashing and making a beeping sound. HELP?
Could be a lost boot sector. Download Testdisk and use it to recreate the boot sector.
2/21/2019 8:39:14 AM • Seagate... • Answered on Feb 21, 2019
Can I format the seagate plus drive to win & mac and is so how?
Hi, Format the drive in Windows and the MAC will read it fine ..
2/19/2019 4:49:08 PM • Seagate... • Answered on Feb 19, 2019
My laptop does not read my seagate external hard drive. It does work on my work computor
Try the following, change the usb port you are plugging it into.
2/7/2019 10:38:48 AM • Seagate... • Answered on Feb 07, 2019
Seagate (ST320014A) (st320014a-25tpk) 20 GB Hard Drive Logo
Popular Tags
4 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
seagate hard drive model st320014a
  • Computers & Internet
