Master
- Posted on May 27, 2009
Re: remove fuel pump from tank ford windstar 98
To gain access to the fuel pump, it is necessary to remove the fuel tank.
Depressurize the fuel system and remove the fuel tank from the vehicle.
Remove any dirt that has accumulated around the fuel pump module
attaching flange, to prevent it from entering the tank during service.
Turn the fuel pump module locking ring counterclockwise using a
locking ring removal tool or a brass drift and remove the locking ring.
Remove the fuel pump module.
Remove the seal gasket and discard it.
To install:
Put a light coating of grease on a new seal ring to hold it in place during assembly. Install it in fuel tank ring groove.
Insert the fuel pump module into the fuel tank, then secure it in place with the locking ring. Tighten the ring until secure.
Install the tank in the vehicle.
Install a minimum of 10 gallons of fuel and check for leaks.
Install a pressure gauge on the throttle body valve and turn the ignition
ON
for 3 seconds. Turn the key
OFF
, then repeat the key cycle five to ten times until the pressure gauge shows at least 30 psi.
Check for fuel leaks at the fittings.
Remove the pressure gauge.
Start the engine and check for fuel leaks.
i need to remove fuel pump from tank. how can i do that
What is it that you need to fix and how can i help you do that??
ok..., can you be more specific please????
the small hose that goes into the gas tank has a hole n started leaking gas
my fuel gauge is inaccurate I installed new fuel pump but it is still inaccurate what could be the problem
