The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
I don't have a Jazzy 1113 ... mine is a jet 3 ultra and the controls seem to be identlcal and it too acts similarly particularly if I come to an abrupt stop by hitting an unseen object on the floor or a slightly raised threshold.
What I do is turn it off (power button) and after a few seconds turn it back on and find that the chair is ready to go again then I back up to see what that I hit.
The chair is very sensitive to approaching a threshold and the correct method is not to do it at an angle but in a direct (not angular) fashion.
Hope it helps,
Joe
Error Code 9 is a "Communications Error". The controller, or "Little black box" down inside the chair is not talking to the joystick, etc. First, check all the connections. Unplug, examine and clean all of the connections going into the controller, and the joystick connection too. Inspect all of the cables for damage to the wiring. If all looks good, then you likely have a bad controller....ouch. These are very expensive to replace new. You might be able to find a used one on Ebay, etc., or you could be better off looking on sites like Craigslist for a complete powerchair replacement. I have found near-new chairs for under a thousand dollars. Search for Pride Jazzy chairs too...a lot more of those for sale than Invacare chairs. Good luck.
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
