Re: funde los fusibles del portafusibles del carro
Tienes un corto en alguna parte identifica cuanles son los fusibles y revisa los circuitos no antes de ver si los fusibles son de la capacidad necesaria
Si su Bush Freezer M5085UCFR dej? de funcionar, hay varias cosas que debe comprobar. Primero, aseg?rese de que est? conectado correctamente a una toma de corriente segura. Si est? conectado correctamente, compruebe que la luz interior est? encendida. Si la luz interior est? apagada, desenchufe el congelador y desconecte la tapa del termostato. Limpie los contactos con un pa?o h?medo y vuelva a colocar la tapa del termostato. Si la luz interior sigue apagada, sugerimos llamar a un t?cnico en refrigeraci?n para reparar su Bush Freezer M5085UCFR
First, is the compressor running? Remove the cover on the compartment where the compressor is located and see if is warm to the touch. Turn the cold control down to the lowest setting and wait several minute then return the control to its normal setting.
If the compressor is not running unplug the unit and look for the black box on the side of the compressor. Usually there is a spring retainer on the top of this box housing the compressor relay and a fusible link. Before disconnecting anything make a diagram or take a picture showing how the wiring is connected.
Remove the link and see if it is intact. Any other checking of these components will require the aid of a multimeter and/or substitution of working parts (i.e. fusible link and relay).
Hope that helps.
Antes de gastar en partes nuevas, debes desarmar el aparato y inspeccionar. Le llega la corriente al motor? Funcionan los switches de limite (que detienen al motor en su punto), algun engrane, o fusible quemado?
Check for blockage in the water line in the freezer. If so, defrost it. Might need a new water valve. Maybe a bad ice maker too. Another possibility is that it's not cold enough in the freezer. Should be below +10F.
Defrost cycle causes it. It comes from humidity in the air. You might have a blocked drain line. Try defrosting the unit for 24 hours and clearing the blockage in the back. There should be a half inch hole for water to drain out.
PARECE SER QUE LA FALTA DE FRIO EN EL CONGELADFOR SE DEBE A UNA FUGA DEL GAS. EN CUANTO AL GOTEO DE LA CUBITERA, ES LA JUNTA DE ESTANQUEIDAD, QUE SE HA PASADO.
