You should be able to assign Abby FineReader 11 Pro as the OCR software in the Lexmark software (Lexmark Productivity Studio for Windows or All-in-One Center for the Mac OS). You will need this software though and to have the monitor running to "listen" for the scan button to be pressed. You will also need to ensure your firewall doesn't block communication if you connect the X6650 through the network.
In the Productivity Studio (launch Lexmark Home), click on the Settings tab and then the Scan Destinations option. Add Abby FineReader 11 Pro to the list of destinations. Click on that option and click on the Modify button to make sure that the Application button is set and is pointing to the correct program and correct file type. Then you can go back to the all-in-one and press the Scan button. Select Scan to Computer and then choose Refresh to update the list of destination programs.
I hope this helps. The steps may be slightly different in the Mac software.
for scanning you can use every program that supports scanning (irfanview is freeware, ABBY finereader and many others). You can try new version of smarthru (for samsung SCX 4300).
pifonski
please install all the fonts . On the"stupid" computer you don't have the exact font ...Save the fonts from the wise PC and copy to the stupid one. It make it wiser . :P . Usually fonts are found in folders named "fonts". Windows, Office and Abby Reader are using large collections of fonts.
Which operating system are you running? If Windows, in the Control Panel is a program "Add or Remove Programs". Click on it and locate your program you wish to remove from the list.
Use CapturePerfect ver 2.0 downloadable free. Ver 3.0 is priced.
http://software.canon-europe.com/software/0022439.asp?model= though this is under Canon 5020, it works with 9080C.
Have you loaded Device drivers, if not download from http://software.canon-europe.com/products/0010035.asp
Once the driver is loaded you can even use Microsoft Imaging to scan. CapturePerfect is easy and brings out the added features of Canon 9080C.
S. Mohan, Chenai, India
