When I start the oven you can smell fumes. I have to open the kitchen window when I first turn on the oven After a few minutes the smell of gas is gone. The stove is model no mgs 5875 BDB I purchased the range in 2007. The retailer has replaced the ignitor. The professional gas installer has been here several times to check the. Gas lines. Also had the fire department come and make sure all is good !!!
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
SOURCE: Trouble lighting oven, smell gas
Sounds like an igniter problem to me. They are heating elements with a limited life & are quite easy to change. There is one for the broiler on the top as well. Why not try swapping them to confirm this diagnosis. If you never use broil then your problem may be solved!
SOURCE: MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
dfasfdas
