20 Most Recent Maytag MGR6772BDS Gemini Gas Kitchen Range Questions & Answers
every right to be concerned
you have a gas leak that will explode doing a lot of damage
as gas in not the DIY domain , call an accredited gas fitter to fix the problem
in the meantime do not use the stove until it is fixed
Maytag... | Answered on Jun 22, 2017
This repair you had done was to repair and prevent the door to the upper oven from building with gas as the broiler was know to do. This was a safety issue for the time period UL required. You can select the low broiler to speed up you preheat time but there is no known fix to by-pass this mode. Sorry for the bad news, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Maytag... | Answered on Apr 09, 2016
Same problem here - and I have read about others with this problem. Usually blamed on moisture getting into the control unit ( which is under the backmost burner knob). I did not have a spill on the cooktop, nor was I "over zealous" cleaning. Looks like a bad design. Waiting to hear from the technician how much THIS is going to cost me...
Maytag... | Answered on Mar 21, 2016
Hi Larry
Use a multimeter on AC range to test for voltage on wires going to bad element.
It's probably a bad switch or open element.
Elements often unplug for replacement. Don't always show damage of burned out conductor. So... Use your multimeter on the ohms scale to test for continuity at each end.
Upper oven element is likely open circuit and will need to be replaced.
Cheers
Maytag... | Answered on Nov 03, 2015
does it say PF if so hit the cancel button
Maytag... | Answered on Feb 16, 2015
This is simply a bad bake element and one of the most simple repairs you can make. When you purchase your parts through us, we provide part removal/installation instructions for you!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance repairs, parts & accessories supplies. We love our job and love helping out with any type of appliance request that you have.
We hope to hear from you soon and we'd love to get you cooking again, so call on us when you need us. Thanks! Ella
Maytag... | Answered on Dec 03, 2014
Try swapping the old module back in. If that doesn't work, check all your wiring - any one wire from the knobs to the module that contacts ground (the frame) may trigger the module to start sparking.
Maytag... | Answered on Jul 29, 2014
Hi and Wlecome to FixYa, I am Kelly.
This is the Sabbath mode. Why it even exists is odd in itself.
Hold CLOCK for 3 seconds to disable the Sabbath mode.
This should get it back to normal operation.
Thanks for choosing FixYa,
Kelly
Maytag... | Answered on Mar 11, 2014
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Maytag... | Answered on Dec 30, 2013
Here is a link to the igniter to order and there is also a video on that same page to show you how to make the repair.
Maytag... | Answered on Oct 26, 2013
On a gas oven there is sometimes a lever inside the oven door that needs to be held in open position untill thermocouple heats up around 15 seconds
Maytag... | Answered on Oct 22, 2013
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
169 questions posted
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Kitchen Ranges
Most Popular Question
upper oven not heat up neither element
  • Kitchen Ranges
