Heating & Cooling Logo
Posted on May 22, 2009
My goodman aircondition system takes forever to cool
Jerico1234
Level 1:
  • Contributor 36 Answers
  • Posted on May 23, 2009
Jerico1234
Contributor
Level 1:
Answers
36
Questions
0
Helped
13073
Points
79
You can have one of two problems .... firstly ,the condenser ,i.e outside part of the unit could be dirty or inefficient in loosing the excess heat or secondly ,the gas (freon) in the system have leaked out ...if it is the second ,the thinner line of the two leaving the condensing unit will start to get ice forming on it .... let me know if this helps
Input and output power to the compressor, for Goodman CPF 60-5B, also we need to know the COP.
Dear fixity a I am close to buy aircondition cpf60-5b goodman but I don't know how many btu is ? Please let me know 17123664-da8b-4955-af47-988622d12fc0.jpg
Leak in air handler goodman aircondition
drain pan stopped up or rusted through. if you are talking freon leak has to be repired by a pro.
1helpful
Aircondition not cold but rear aircondition seems cool only.
Check for the refrigerant charge. You may have a leaking system.
My aircondition system is not getting cold
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
I have a goodman airconditioning unit, I have my AC set on 75 inside. the unit gives excess water outside the unit and floods my yard..is this normal? any fix?
your unit shouldnt flood your yard .. now check your unit to see where your drain from your unit ( inside)is going .. if that is going outside where your unit is then there is where your water is coming from..
Every 1 minute it has a one second surge
Hello Dave,
The first place to start is with the line voltage supplying the condensing unit. Check ALL line voltage connections at the condensing unit, the service disconnect, and the electrical panel box. If you have a weak connection or overheating circuit breaker, it could create these surges.
Don't forget to ensure the filters and coils are clean to keep your system operating at peak performance & efficiency. :-)
I am looking for how many tons of cooling my goodman condensor provides
  • Here's the data you requested:
  • Goodman CKL42AR42 Split System Air Conditioner
  • Type: Split System
  • Cooling Capacity: 40000 BTU/hr (3.3 tons)
  • Energy Efficiency Rating: 9 EER
3helpful
I have a Goodman GMT070-3 furnace. When I turn it
if it is a fuel furnace the pump may have air in the system. here is a web site that will give you the information you will need to to help you fix the problem, there is a manual that will take you step by step to resove the problem, if you need more help understanding the troubleshooting of the system post to this e-mial you will get.
http://www.aircondition-units.com/pc-72-25-gms90703bxa-gas-furnace.aspx
Airconditioning problem on 92 cavalier
Your Orifice tube is probley clogged and needs replaced i wouldnt recomend this be done by someone not trianed to do tho also with new laws regarding freon unless you have acess to a reclaimer it is illegal to do becuase entire sytem has to be drained to get to tube
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
