SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
