20 Most Recent
Altec Lansing ACS 45.1 Computer Speakers Questions & Answers
Speakers Died?
No, I think you've fried only the fuse of Altec Lansing. Check at the back of the main unit (subwoofer) if there's a fuse box (should look like head of the plastic bolt). If not than turn it off, unplug it and open op the main unit and check for the fuse. It should look like this:
If the metal wire inside of it is broken than you should buy new fuse of same amperage (it should be engraved on metal part of the fuse or printed on glass tube).
Trying to connect to TV but only center speaker
Hi there bud ...Are you sure you using the RCA Cables , and not just the Cables that came with SPeakers?
Also make sure THat your T.V can handle 5.1 Channel Sound Speakers..
Hope you come right bud
Happy new year
Ah i have altec lansing
ok first plug run a1/8 two sided head phone jack[male] from the computer to sub woofer you should have two imput jacks makes no differance ok the left sat speaker has a 6 pin din plug round looking plug insert into subwoofer and then plugac cord in the wall you should be good togo "note right sat speaker is attached to the left good luck
Static electricity shock blew a circuit for the speakers. The power light is on, but no sound.
click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow question / exclamation ? ! mark or a red X right click to update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
if your computer came with a motherboard disk the drivers could be on it hope this helps
The speakers doesn't turning on/... even
a motherboard disc the sound drivers could be on it
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
Acs 45.1 We have the
-->The pin cable goes from the control speaker to the base. Red connector in this picture.
--> The 1/8" mono goes from the other speaker to the control speaker. White mark in the control speaker.
--> the SW has 2 inputs (m-m 1/8" stereo cables) 1 comes from the audio out of your sound card,
the other is the subw input, you can connect this if your sound card has that output.
Good luck
Rate my response please.
My problem is when i
Your altec lansing need to be open, because it has a loss connection on the power supply part of its circuit board. that is why when you turn up the volume it turns off because it produces vibration enough to shake the circuit board which has a loss connection.
1. Prepare the following tools:
* soldering gun/iron / soldering lead and a magnifying glass
* open your altec lansing cover enough to see the circuit board
2. Try to examine the leads on the circuit board, try to share some of the spare parts make sure it is not plug to live outlet to avoid electric shock.
3. if you see some spare parts shaking try to resolder it.
4. Then close back the cover.
5. Then test your altec lansing
