A
Anonymous Posted on Jan 04, 2014
Ipad disabled - Audio Players & Recorders
2answers
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
My psd is disabled as i put in code too many i used a usb plug and hit i tunes but it did not disabled it what can i do to unlock it
I think you're talking of your ipad being disabled (psd=pad?).
If you happen to have a backup in itunes back from when you still knew your passcode you can restore your ipad to that backup. If not you have to revert your ipad to defaults and install all your apps from there again.
Use this Link to learn how to put your ipad into recovery mode:
If you can't update or restore your iPhone iPad or iPod touch
My ipad is disabled
You need to connect the iPad with an USB-cable to a computer and open iTunes software. there you will see your iPad showing up and you can do a restore:
ipad-disabled-nafmevug3d2144tx52q0vcxn-4-0.jpg ipad-disabled-nafmevug3d2144tx52q0vcxn-4-5.jpg Restore iPad to new factory condition
2answers
Ipad A1396 is disabled it says to connect itunes but itunes does not connect or recognise it
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
Ipad says disabled
http://support.apple.com/kb/ht1212
If you don't remember setting up a passcode on your ipad, maybe someone else did, and then entered the wrong passcode more than six times, resulting in a disabled ipad.
In the link above you will see instructions on how to deal with this problem, which pretty much boil down to connecting your ipad to itunes and restoring from a previous backup that you may have saved.
If you never created a backup, you can still reset and wipe your ipad from itunes, resulting in everything being erased, but at lease giving you back full use of your ipad.
My mini ipad says disabled how can i enable it again?
Did you mean that the iPad is disabled for many attempts of passcode? Usually, waiting for a particular time span can enable agin the iPad. But if does not enable back again even after a few hours, then consider restoring your iPad in iTunes.
4helpful
3answers
My ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
 Grubhead
Grubhead
SmartAviator
SmartAviator
