Question about Apple iPad (16 GB) WiFi Tablet PC
My iPad is disabled asked to try again in 22,377,564 minutes
My iPad is disabled it telling me to try again in 22,377,564 minutes
Virgil Wolter
  • 29 Answers
My IPAD says IPAD disabled try again in 24759146minutes how do i open it up
Your going to have to wait 24759146 minutes. Or you can just restore to factory setting. Only do so if you have everything backed up. Or if you don't care about anything on ther then Factory settings it is and it'll be ready to be used.
Dec 29, 2017 | Tablets & eReaders
Ipad is disable
If your iPad has been disabled, it is completely locked down. The only way you'll be able to use it again is by restoring it using iTunes or iCloud. If you have a backup, you'll be able to recover your data, but this process will delete everything that is stored on the iPad. Except for the following methods, there is no other way to unlock a disabled iPad.
  • Using iTunes
  • Using iCloud Find My iPhone
  • via Recovery Mode
  • via DFU Mode
How to Unlock Disabled iPhone with without iTunes
Sep 05, 2016 | Tablets & eReaders
My IPad mini is showing info when I open it -disabled try again in 60 minutes, how do I fix it
you need to connect your iPad to a computer that has iTunes then hard reset it by pushing the sleep /wake and home button till you see the iTunes logo on your phone, then you'll see and option on the computer screen to restore, then click restore then wait for it to finish, then you can setup your device like new
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Jun 23, 2016 | Apple iPad Mini
It is disabled says try again in 23795058 minutes
I advise you not to wait. If you have an laptop or desktop you need to download itunes. After downloading connect your device make sure its off. Once off and connected hold home and power button until itunes logo pops up. On the laptop or desktop a sign should pop up saying recover or update press recover if its says you need to update then update and wait until its finished. Then press recover and you should see the ipad change screens. After that process you should see multiple languages. Now you have reseted your ipad.( if fails try again)
Jan 12, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Keep telling me iPad is disabled try aain over and over
Take it to an Apple store and ask for help
Sep 26, 2015 | Apple iPad Mini
Ipad troubleshooting
Try resetting the iPad, by pressing both the home button and the on / off switch, till the iPad switches off. (can take about 10 seconds)
then switch on with the on / off switch. the white apple loge should appear and within one minute it should work again. If the light stays off, contact an Apple store and ask a Genius on the Genius bar.
Aug 28, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do I unlock a disabled ipad 2?
First try to reset the iPad, by pressing both the home button and the on / off button, till the apple logo comes on the screen. Then try again. You should have a password for you Apple account, because that will be asked. If you don't have an account name for the device not worth trying, because it will be blocked anyway.
If this does not work, why not try one in this link?
How to Reset Forgotten Password for an iOS Device
Aug 02, 2014 | Apple iPad 2 Wifi 16GB
I forgot my password, and disabled my ipad mini , and need to get back into it
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Dec 02, 2013 | Apple iPad Mini
Apple iPad (16 GB) WiFi Tablet PC Logo
226 people viewed this question
Top Apple Tablets & eReaders Experts
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
