Kitchen Appliances - Others Logo
L
Lee Desmond Clegg Posted on Jan 03, 2014
Rational oven I need to remove the fan can't find a puller that size any suggestions please
Rational SCC201G/N is an intelligent natural gas Self Cooking Center (combination oven). There is error E-34. Please help.
Question edited for clarity.
Question moved to maker category.
All Rational Ovens need dealer service.
Service 34.xx
  • What's the cause? Bus signal problems
  • Probes (x):
    • 34.1: Motor top
    • 34.2: Motor bottom
    • 34.4: Ignition module top
    • 34.8: Ignition module bottom
    • COMBINATION OF BUS SIGNAL PROBLEMS CAN DISPLAY (EXAMPLE: IGNITION MODULE TOP AND BOTTOM WILL DISPLAY AS "34.12?)
  • Remedy? See if the bus cable plug and cable connection are connected or damaged
https://www.google.com/search?q=rational+scc201g+error+E34
2answers
The new Rational iCombi Classic Single 10-Full Size Combi Oven leaks from the underside. Does anyone know why? How can I solve the problem?
Question edited for clarity and add maker '(what it is)'.
Question moved from Refrigerators.
I recall that ours did this. At the front underside they is a small removable hopper that is the first part of the drain. Make sure it is correctly located and level.
Or, call the installer back. Rational telephone help is also very good.
https://www.google.com/search?q=iCombi+Classic+leaking+on+steam+cycle
4answers
Error code 51 on Rational combo master plus. Changed battery but error 51 still displayed, any advice ?
Error 51 I perform cleaning the steam generator and all source of water and I change battery also but still error is appearing to please give me solution
Rational CombiMaster Plus System. Good evening, I have a problem with the oven that I have, which is the appearance of E17, and the oven is off. Please help, thank you.
Steam Generator Issue. Call for service, you can't fix these yourself as they are fully computer controlled. Maintaining them is a cost of doing business.
RATIONAL COMBI MASTER PLUS'SERVICE ERROR CODE'S
thehanadvisor.com https://www.thehanadvisor.com > ... > RATIONALCM
Each code will tell you what's wrong with the oven, allowing you to tackle the issue quicker. NOTE: PLEASE SUBSCRIBE E MAIL AND YOU-TUBE CHANNEL. OPEn / H2o.
more here
https://www.google.com/search?q=rational+combimaster+error+code+E17
Manual
https://www.rational-online.com/media/downloads/en-gb/manuals/rational-original-operation-manual-cmp-en-gb.pdf
May 28, 2023 • Ovens
2answers
What does it mean .. 34 / 16 service
Question Edited to add make and 'what it is'.
Question moved from Larry's Computer category and dropped into Rational.
Rational Cooking centre are so overly technical, only their own engineers can solve the coded issues. The last place I worked, we bought one for $45,000 and it cost $16,000 to run 60 amp 3 phase power, water and drainage to it. It needed 2 service calls in the first 6 months. They are great when they are working and the self cleaning feature is magical.
RATIONAL SCC 201 G: spare parts, technical drawing, device ...
https://www.gastroparts.com > scheme-186885
Plain washer ID ? 6,4mm ED ? 18mm SS DIN/ISO DIN 9021 Qty 20 pcs thickness 1,5mm. shipping today. 560.117 · Axial fan L 119mm W 119mm H 38mm 230VAC 50/60Hz ...
Missing: GGA ‎' Must include:
GGA
Installation Manual
https://www.rational-online.com > files > en_us_1
PDF
20x1/1 = SCC WE/CMP 201 G/E. 20x2/1 = SCC WE/CMP 202 ... On floor models (20x1/1 GN and 20x2/1 GN) there ... supplied unless unit is connected using AGA/CGA.
Missing: iso ‎' Must include:
iso
Rational SelfCookingCenter 5 Senses Combi Oven - Nella ...
https://www.nellaonline.com > products > rational-selfc...
Rational SelfCookingCenter 5 Senses Combi Oven - Model SCC 201G ... Cooking appliance for automatically cooking (Automatic mode) meat, poultry, fish, ...
Missing: GGA ‎iso
Started clean cycle on rational oven and ran for a bit and clean cycle aborted. and would clear on the screen. How do we reset rational
Use something similar size to the rational pills, place it where you would normally put the pills for cleaning, go to start the cycle, then pop the door before you press start, should trick the rational into unlocking,
Nov 14, 2018 • Ovens
I have a rational combi oven electric 3 phase model number cd61 can anyone help that when should the oven fan motor start after the oven is on and how to test the motor
The motor should start as soon as the door is closed.
to check the motor, I need to know the s/n. Some motors use contractors, others use electronic motor control.
Apr 20, 2016 • Combi Ovens
What is error 34-7 we have 8 rational oven in over hotel
I m working on a rational oven CMP61. I repaired the Fan Motor PCB but led light this blinking 7times with motor installed on PCB. Without motor installed on PCB led blinks 11times.
What must the problem give some hint or guidance.
5helpful
2answers
My rational selfcooking center says service34-2- no function please help
You really need a specialist repairer to resolve this but this generally relates to a main fan motor defect or a failure elsewhere in the bus circuit.
Sep 03, 2011 • Ovens
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
