SOURCE: gas line with filter broke inside tank how to
get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
SOURCE: Ryobi 31cc 17" trimmer. When I pump the prime bulb
need to relace the prime line with a longer line...
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
