i have already done that and it has been 3 days now but it just doesnot helpi have already done that and it has been 3 days now but it just doesnot help
You can't post conmments that contain an email address.
its flat of lcd is not working good and u may change ur lcd.but it may be from its IC, that time there is no way to solve. call ur cellphone when its lcd is blank if it is working change the lcd. cheers
You should not have tried to use it right away. You should have immediately pulled the battery out and then blow dried it and put into the rice bag for 24-36 hours. Because you tried to use it is shorted out. You will need a new phone as it is probably not going to be able to be fixed. Sorry!
If you open your cellphone after falling it to water,its possible to damage the keypad circuit because of shorted happened in the circuit board when it fell, so better to look for a cellphone technician to troubleshoot it to avoid major problems.
It is stuffed, if it falls into water then the second it falls in it will short, and probably blow some critical components inside, even if the phone is off then there is always power running through it (so it knows when you are pressing the button to turn it on, also so it can remember the time and date)
Have you tried a Full Reset? You can do this by pressing the Power button and **** the small reset hole near the base of your O2 at the same time. Try it if it works.
my zen stone player fell into water. it was off at that time, but i didnt switch it on. i try to dry using a drier & after 2 days, when i felt it was completely dry, i switched it on.. but the buttons are acting crazy & its not recharging. wat should i do ? please help me.
yes it is bad
getting hot means that the internals are frying or shorting out
leave the battery off of it for about a week then try it again.
I really don't like your chances of it working properly again though.
Good Luck
