SOURCE: Green and Red Lights on my Parrot minikit slim/chic are flashing
Spoke with Parrot, was told that the batt had been left to run to low and I had tried to use it.
let the batt run right out and all will be ok.
I know put on charge veryday and have to had the problem again
SOURCE: Parrot MINIKIT Bluetooth 1.02c do you know the
the 1234 or the 0000 are the most common code used by the manufacturers.
SOURCE: clearing parrot minikit memory
Just press on the green and the red buttons at the same time, you will have erasing memory in progress, please wait. And then please pair device.
SOURCE: pair parrot minikit 1.03C with
Press and hold both the red and the rotary buttons for some 3 seconds, until the indicator light flashes alternately in red and green. It is in pairing mode now, thus visible for other devices, for the next 3 minutes. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If the pairing process is successful, the car kit should sound a beep. By the way, if your car kit's user guide happens to be missing, feel free to download it from this location. You will find many details about settings for your car kit there.
Please, let me know if I can help you any further.
Regards,
Carlos
