SOURCE: Xerox Phaser 8560 - Changing Menu from German to English Language
To select the default language on the Control Panel:
To select the default language using CentreWare Internet Services (CWIS):
If you are talking about the driver menu you have to delete and reload the driver with the english
SOURCE: Green and Red Lights on my Parrot minikit slim/chic are flashing
Spoke with Parrot, was told that the batt had been left to run to low and I had tried to use it.
let the batt run right out and all will be ok.
I know put on charge veryday and have to had the problem again
SOURCE: Need to change language from german to english.
If you are talking about one of the Casio QT6xxx's then you need to.
I . All peripheral devices and terminals of this cluster should be turned off.
2. Connect all of the peripheral devices (such as printer, display etc.) to terminal.
*In case of wire inline:
3. Connect all terminals by inline.
*In case of wireless inline: QT 6000 or QT6600 models
3. Connect Wireless LAN card.
Operation:
4. Turn on all peripheral devices of a terminal.
5. Turn on this terminal while pressing and holding the initialize switch and then release.
6. Next the screen will say push the INIT (initialize) switch to start IPL.
After releasing the key
The IPL will take a few minutes to copy over.
When it is done, Pick the Language you need. enter"20000" (U.S.)," l0000" (other area:English)," 40000"
(other area:German)," 50000" (other area: French)," 60000" (other area: Spanish) and
press the <OK> key.
I will be making a video of this procedure this week, so visit us @ www.casiohelp.com to view it.
